LRP SXX StockSpec V2 ESC >
Old 07-23-2011, 08:57 AM
  #496
MeBeMikey's Avatar
Originally Posted by JimmyMac
Good luck with sending it back. My friend sent his back months ago and still waiting on a replacement. They told him they do not have any in stock. He keeps getting the "in two weeks" comment from them. So far, mine has been working out great. I just feel sorry that I recommended the LRP to him because his Tekin keeps loosing boost mid race.
For his Tekin, add more throw to the forward throttle points. Loss of boost is due to the Tekin not seeing Full Throttle. Go +10 after setting Tekin up on 0.
Use the Tekin while yah wait for the SS to get back.
MeBeMikey is offline
Old 07-23-2011, 10:41 AM
  #497
Mikkel_R's Avatar
Originally Posted by MeBeMikey
I Havnt been for a while. Have they changed the track again? If it's the track that was used for the 24 hour race I think I was doing constant 24's in the 310 area.
If they made a new track I'm quite excited to run there again soon as I have just made some changes to my car that gives it very good on power steering that pulls hard and fast in corners.
The track I raced at was Rugby. Very small track.
Hi Mike,
Yeah theyve changed the track more technical and tight, Ive geared up to 5.5 and raised the boost to level 5. Car pulls really well and max motor temp was 70'c. Best times for me is 21 laps in 304 with fastest lap at 13.68.
Mikkel_R is offline
Old 07-25-2011, 06:27 AM
  #498
Chris08527's Avatar
Trader Rating: 16 (100%+)
what settings are you guys using for blinky 17.5, i used it this past weekend but i need to figure out the brake settings???
Chris08527 is offline
Old 07-25-2011, 12:53 PM
  #499
piper48
Guest
Posts: n/a
Default blinky racing
Is the SXX StockSpec V2 better for stock blinky than the SXX Competition V2? If so why is that? Thanks in advance.
Old 07-25-2011, 01:06 PM
  #500
Chris08527's Avatar
anyone know what size screws to use to attach the esc fan???
Old 07-25-2011, 06:56 PM
  #501
H I
H I's Avatar
Trader Rating: 18 (100%+)
I can think one thing better about SS will be ESC heat sink.
Cooler ESC = Better performance.
H I is offline
Old 07-25-2011, 07:17 PM
  #502
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Chris08527
what settings are you guys using for blinky 17.5???
+1........and while I'm at it, how about a FDR for a D3 on a fairly large asphalt track with medium grippage. I'm running a 3.82fdr/ 1 tick away from full endbell timing. Nice bottom end but I'm lacking topend. There's also a fan on the motor and yesterday on a hot day I was around 170degrees all day. 88/46/2.0 internal
Thanks guys
JayBee is offline
Old 07-25-2011, 08:25 PM
  #503
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
lem lem...The SS throttle drive just more aggressive than the SXX Competition..
OVA is offline
Old 07-25-2011, 08:35 PM
  #504
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Thanks guys
Go to a taller FDR, but with a bigger spur. Say like 96/52 (3.69 FDR). The bigger spur helps keep the bottom end, and the taller ratio for the top. Also from what ive seen locally, less timing, more gear seems to suit D3's better.
geeunit1014 is offline
Old 07-25-2011, 08:39 PM
  #505
JayBee's Avatar
Now thats something I'm definitely gonna try About what range in endbell timing though?
Thanks geeunit.....
JayBee is offline
Old 07-25-2011, 08:41 PM
  #506
OVA
OVA's Avatar
Thanks guys
JB your car was right there with Jake for a few laps..you tap the pipes and the cost.. I take the back...3.7 is the ideal gearing for me.
OVA is offline
Old 07-25-2011, 08:46 PM
  #507
OVA
OVA's Avatar
Thanks geeunit.....
Anytime you reduced the timming the end bell..you should gear taller..
I have on the 92/49
OVA is offline
  #508
Thanks geeunit.....
I would probably say around 1/2. Ive seen a few guys run 3.55FDR/0* endbell, but their cars looked flat on the straight. Saw a friend run this past weekend, I think he was around 3.6-3.7, and around 1/2 on the endbell, and he was definitely not lacking on the straight.
The gear thing is something we've found to be pretty effective, the spur is the motor's leverage for the transmission, so the bigger the spur, the easier it is for the motor.
Old 07-25-2011, 08:48 PM
  #509
JayBee's Avatar
I have on the 92/49
Thanks for the encouragement buddy.....will do I'm gonna still make changes though.
JayBee is offline
Old 07-26-2011, 07:55 AM
  #510
Default more speed exiting
hi,
my setup
SXX StockSpec V2 (3-5-5-0)
LRP X12 13,5T (ºººº) (75ºCelcius)
chassis: T3, FDR: 6.13 (84/26t)
battery: VTEC 5300mAh/40C
Track: Asphalt, quick, grip, big, 65meters strait (Cancela - Funchal)
I need more speed exiting the corners,
should I change the motor timing?
if I change it, do I have to reduce the pinion
should I increase the Fell or the Boost?
thanks for any help
duartev is offline
