-   -   Icharger 106b+ (https://www.rctech.net/forum/radio-electronics/465519-icharger-106b.html)
bigjayjay1 12-30-2010 10:41 AM
Originally Posted by drewmugx5t (Post 8401810)
I got a balance board for it and it doesn't seem to want to work correctly. I plugged the board onto the 6S port and plugged the battery into the 2S port. When I go to charge it it says the balance port is not connected.
I just wanted to be able to extend the balance lead so I don't have the battery sitting so close to the charger. Am I doing something wrong or do I need something different?
That weird I use the protek board for MULTI balancing and charging option and it works perfectly. Maybe its the brand and how its wired.
bigjayjay1 12-30-2010 10:42 AM
Originally Posted by Duster_360 (Post 8403178)
Don't know first hand, but this is an iCharger dealer and says it will work, mentions the 106b+ specifically -
http://epbuddy.com/index.php?main_pa...products_id=70
Email him and find out for sure.
Yup thats the one I have work fine no issues.
simplechamp 12-31-2010 08:08 AM
I'm just stupid and didn't use the most negative port. I thought you could use any of them, but apparently with just the single 2S pack you can't. Seems like at the time I would have tried all three, but must not have.
Duster_360 12-31-2010 09:21 AM
Not sure what you mean by most negative port?
gulio 01-01-2011 07:01 AM
got main lead plugged in too? :o
crusey_aus 01-01-2011 08:50 AM
There is 3 x 2s ports wired in series
If using a single pack you must use the one with the negative lead (right side)
The centre and left sockets will not work with a single pack
Cheers
Duster_360 01-01-2011 09:12 AM
I know that, I have one and use it for single lipo (3010b), just curious what he meant.
