Charge settings for Different Type of LiPo? >
Old 12-19-2010 | 08:28 PM
DOMOisCOOL's Avatar
Default Charge settings for Different Type of LiPo?
I'm currently using a few LiPo packs for an Airsoft gun. Specs are as follows for the entire pack:
3 cells
11.1v
1300mAh.
15c/burst 25c
I'm currently using a LRP Pulsar Comp 3. I'm familiar with NiMH settings, and I know the charge settings for NiMH packs.
I need the best settings for the best possible performance per charge.
Any rough estimates would be great.
DOMOisCOOL is offline
Old 12-19-2010 | 08:35 PM
Charger should have a dedicated lipo charge mode that automatically selects some of the settings
You should just have to use the following
Cell count - In your case 3 (3s, 11.1v)
Charge rate - In your case 1.3 amps (1c charge rate equal to battery size)
Cheers
crusey_aus is offline
Old 12-20-2010 | 06:50 AM
Unless your lipo packs say 2C charging, the best rate is 1.3amps in lipo charge mode, with it set for a 3S lipo. The charger shoud not let you charge it if it senses the voltage is off from what you've told it. A 3S should be above 9v for the charger to recharge it.
Duster_360 is offline
