-   -   Swapping motors between races (https://www.rctech.net/forum/radio-electronics/460048-swapping-motors-between-races.html)
stang2244 12-09-2010 12:24 AM
I am currently running my Blitz in the Short Course Mod and Short Course Super Stock classes. I have a novac havoc pro ballistic 10.5t for the Mod and the same motor in a 13.5 for the Super Stock. I have just been running the 13.5 in both classes because there isn't enough time to de-solder and re-solder the connections in the 1 race gap between the two classes. I am wondering if it would be alright to use the single wire connectors for each of the three motor wires so I can just pull the two motor screws, pull the wires, and vice versa to swap motors between races. Any advice would be much appreciated.
pyro18t 12-09-2010 12:34 AM
Sure why not! just use some bullet connectors!
Jay
kevinmajor 12-09-2010 06:59 AM
+1 on bullets.
Just make sure you shrink wrap them so they don't short out on each other.
racer53 12-09-2010 07:14 AM
+1 on bullets.
Yes it works great thats what i do
stang2244 12-09-2010 08:20 AM
Awesome, thanks for all the replies. I will be putting those on before the next races!
shanem121 12-09-2010 09:48 AM
Bullets are the way to go. 2 screws and your motor is out. But DO NOT forget to heatshrink the bullets. Or you will have a problem.
