M11 drop down
Old 12-07-2010 | 09:59 PM
Default M11 drop down
I have a M11 set up Left handed: does anybody have drawing or instructions how to drop the steering wheel lower? Thanks!
bowl806 is offline
Old 12-07-2010 | 11:26 PM
[[john]]'s Avatar
R/C Tech Elite Member
Hi Mate, you need to undo the two screws holding the 'Top' part of the radio to the 'Base/Handle' - There is one at either end & IIRC they require a 3mm Allen Key/Driver.
Once you've removed the top, the two brackets that were holding the top in place (The brackets where the screws removed screwed into) can be unscrewed (IIRC they are phillips head) - Then you can raise or lower those brackets to raise/lower the top of the radio; in-turn lowering the wheel.
If you can't understand my instructions above (I don't blame you ) Its somewhere near the beginning of the manual.
[[john]] is offline
Old 12-08-2010 | 07:35 PM
Believe it or not that makes sense lol! (Never thought about checking the manual duh!)Thanks for your help!!
bowl806 is offline
