Tekin issue
I was trying to set up my brushed tekin ESC yesterday and I tried to do the setup to calibrate and it acknowledges the neutral position, throttle but when I try to th the brake function, it doesn't beep.
When i turn it off, then back on, it acknowledges the brake by having the bottom lit when the brake is applied. anyone else have this problem?
I had that happen once when I had my speedo set to brushed mode with a brushless motor attached. The wrong mode or T/B endpoints not maxxed on the radio and the Tekins will refuse to complete calibration.
