Help balancing
Old 11-25-2010 | 11:34 AM
Default Help balancing
OK so I have a Bantam BC6-10 charger. All this time I have just plugged the balancing wire into the charger and "charged" my battery thinking it was balancing them. I do not think so. I do have several options on my charger; "charge", "fast charge", "storage", "discharge" and "balance".
So now I tried to select "balance" when I start I get the error "Batt Vol ERR cell connect"
Lastly the battery is a Venom 2cell 500mah 3S charge rate battery. I am selecting 5 amp "balance" at 7.4V.
What am I doing wrong?
goin2drt is offline
Old 11-25-2010 | 12:02 PM
You are correct, in 'lipo charge' the charger is not balancing. Only in 'lipo balance', 'lipo fast ' or 'lipo storage' modes is the charger balance charging.
I don't know the charger, but some of these have a connection order, In other words, tthey charger expects the main power leads to be connected to teh charger 1st, the the balance cpnnector to be connected - this is how my Hyperion 0610iNet expects a lipo charge to be set up.
Look at your manual and see if there is anything specific about the order in which these are connected.
Let ne see if I understnad what you're saying - this is a 2S 500mah lipo that can charge at 3C??
Charger compares the voltage from the main power leads to what it sees on the balance conn, if these don't correspond, you get an error. Do you have a way to measure the voltage (DVM/MM)? If this lipo doesn't have at least 6v (2S), its going to cause an error cause teh lipo has been overdischarged.
Duster_360 is offline
