help with range
hey guys.I got a problem with the limtied range that my truggy goes.I wanna be able to drive it out further and still be able to bring it back in.Any sugestions.Im new to all of this so exuse the dumn @$$ newb ?
Limited range can be due to weak batteries, less that optimum installation of the onboard gear, etc. To offer any help, need to know what you're running, what radio, what RC, what batts etc.
There's no universal magic cure all for range probs. |
Car-Traxxas Electric half bandit/half rustler
Motor-Novak SS 8.5 ESC-GTB Reciver-Traxxas 27 MHZ AM/2019 reciver Transmitter-Traxxas 27 MHZ AM/Top Qualifier Battery-REEDY Black Label High Power Ni-MH 7.2v 6cell pack Hope this helps |
the 27mhz radio systems have always had problems it would be best to upgrade to a nicer 2.4ghz radio.
If you want to try and get a little more range without upgrading: 1:Make sure all transmitter batteries are fresh 2:Make sure anttenas on both the transmitter and reciever are extended all the way. 3:Make sure the "truggy" you said you're driving is on full charge. Good Luck. |
Make sure the antenna wire is fully extended - run all of it thru the antenna tube and then secure the part outside the tube with something like fuel tubing or heat shrink. I've seen some that keep the excess inside the RC, bundled up next to the tube, thats not what you want to do for range.
If there's a longer antenna tube available, use it, I use 14 - 16" tubes which help range. Make sure both crystals are fully seated. Always run with tx antenna fully extended. You will not get the range out of AM you'd have with FM. If these tips don't help, upgrade to FM of a good 2.4ghz system. |
Originally Posted by Duster_360
(Post 8232297)
Right now it does not have a antena tube.The antena is wraped around the roll cage.I got this thing to keep me busey here in IRAQ so i dont know alot about these kindda things.Im sure when i get back to the states i might try to find a local track or something.
Originally Posted by 6th gear
(Post 8234494)
^^+1
That is the prob, get o find something that will work as an antenna tube and get the antenna wire up and out of the chassis. You will not have any range running it the way it is now. |
| All times are GMT -7. It is currently 05:54 AM. |
