Charger Options
Am looking for a new charger, and have a feeling my expectations are too high!! Anyway, thought if I posted my wishlist some of you guys could point me in the direction of the best options, please! What I'm looking for, to charge my 2s lipo packs, is:
Mains and 12v input
Fast discharge rate for storage (eg can discharge at more than 1A)
ACCURACY - a good reputation for balancing/not over charging
Nice to have's:
Multi inputs (eg charge more than one pack at a time)
More than 50w (ability to charge 2s at 7-8A)
Ability to charge nimh/life as well
What would anyone recommend? Are fusion chargers any good?
Mains and 12v input
Nice to have's:
Good day!
I use this charger and I am quite happy with it.
http://www.dynamiterc.com/Products/D...ProdID=DYN4064
Yeah, your expectations are way out there compared to whats available. The dual charging capability on AC/DC power doesn't exist as far as I'm aware.
you really need to decide whats important as far as what you want/need to charge and go from there. The AC/DC requirement is really very limiting in the area of chargers. They just don't make them for much above entry level type basic charging.
A fairly close match is the new Hyperion 0720i Net3-AD AC/DC model. Solid rep, 5 amp discharge on a 2s, 90 watts on AC power (150W on DC). Just buy two!
http://media.hyperion.hk/dn/eos/
http://www.allerc.com/product_info.php?products_id=5655
Or if you are willing to go for a power supply the Duo models are double chargers with more power.
Well, even though this charger is dc only, it'll do everything you'll ever want to do PLUS++++ It will be the last system you'll ever need.
http://www.revolectrix.com/pl8_description_tab.htm
This power supply will also service this charger. I just got one & it's great.
http://cgi.ebay.com/36-Amp-12-Volt-1...item563e2925a9
Then if you're willing to go with a single charger instead of spending a big chunk of cash, the newer Hyperion 0720Net3 AD is one to consider. It is AC/DC, has -
"EOS 0720i NET3 AD (ac/dc input)
10.5V~29V DC (20A, 150W max charge)
100V~240V AC (20A, 90W max charge)"
and as far as accuracy - "* 12-Bit Balance Circuit Resolution for superb accuracy".
The discharge specs are 50watts with a max of 5amps. That makes for a relatively fast discharge. Although I prefer to just run a lipo and let the charger charge it back to storage conditions.
Charger specs here - manual is available at bottom of page -
Several places to buy - on sale here -
http://www.allerc.com/product_info.p...oducts_id=5655
or here -
http://www.amainhobbies.com/product_...er-7S-20A-150W
Heres a good deal i just picked one of these up the other day works great comes with dang near everything you need.
http://www.amainhobbies.com/product_...o-Charger-Plus
or here -
or here -
Dual charger (two batteries at once), same functions including the STORE function. Also DC only, but a nice power supply is not that expensive. Again - last one you will need to buy.
Suspended
PS cheaper here.
