Hitec HS-645MG on a rustler?
More than sufficient. Are you going to be using this for your steering? If so, you can take your stock steering servo (2055) and put that on the throttle link. I personally use the 2075 on the steering and 2055 on the throttle. The 2075 is waterproof and relatively cheap (look on eBay). Only downside is it doesn't have metal gears.
