thunder ac6 software
If you had bothered to really look you'd have found a line that said -
"DOWNLOAD CE FOR THUNDER AC6" - when you move you cursor over it, it changes color. Its right under where it says "DOWNLOAD PRODUCT PHOTO" and "DOWNLOAD AC6 manual" . This is in the middle of the page at the top in the advertising box for the charger.
Clicking "DOWNLOAD CE FOR THUNDER AC6" lets you download a zip file that has the software for the charger.
Look again, this time read a little of it before you jump to conclusions.
Don't know why they'd do that, it is some EC driven electrical compliance certificate. Read this, particularly reply 9 -
http://www.rcgroups.com/forums/showthread.php?t=1089940
He found it here -
http://boydhobby.com/Downloads.aspx
I'd try to do the same thing he did, in the same order. Apparently not straightforward or well documented.
I did similar with my Hyperion and have looked at in once. If I didn't have to do it to update the firmware in the charger, it wouldn't have been worth the time or the trouble....
He found it here -
no matter what battery i hook up and start the charge, fast charge, or balance it always goes back to the charge area and doesnt start to charge, ive changed the amps from 3 to 5 and from 4 to 5 and from 5 to 4 or 3 and doesnt matter, any ideas?
on another note this is the only place i have found a good download for this software
Link: http://site.hobbypartz.com/ThunderAC6/setup.exe
