Lipos in TXs
What would prevent a lipo from being over-discharged in a transmitter such as the 3pm?
Originally Posted by CT5
(Post 7975259)
I use a 3S 3000mah I think its 8C lipo in my 3PK and anothe rjust like it in my 3PJS. There is no 'parasitic' drain like when a lipo is connected to an ESC.
I don't take mine out or disconnect them between uses. The only time I remove them is to charge them. Done it this way for over 2 1/2 yrs without any lipo probs. I monitor voltage off the radios display and charge when I get to the point I don't want to worry about it anymore, usually when it drops below 10v. |
On Ebay, there are literally hundreds of lipo monitors. Some have displays and will tell you the voltage of each cell within the battery, some are just low voltage warnings with a buzzer. Most are from china and are really quite cheap - well worth the meagre expense certainly.
The more advanced TX have displays on them, most of which will tell you the voltage of the TX battery. You could also check the voltage of your pack prior to running. A typical TX lipo (any 3s that fits) would give quite some runtime so you could just keep it at a reasonable state of charge by charging it up to storage levels after you run. Lithium batteries prefer partial charges (as opposed to running them till cutoff then fully recharging) anyway. Disconnect the battery from the TX whilst it is stored. |
Thats the whole point, there is really no need to disconnect the lipo. I have 23S 3000mah lipos in 2 diff radios and they are never disconnected except for charging. You turn the radio off, you turn the battery off.
This is not like a esc where there is still drain on the battery even when the switch is off. |
Originally Posted by Duster_360
(Post 7978414)
This is not like a esc where there is still drain on the battery even when the switch is off. X2 :nod: |
| All times are GMT -7. It is currently 01:10 AM. |
