Hitec Raising the Bar >
Old 09-20-2010 | 02:53 AM
  #16
mtbkym01's Avatar
Here's another one.......
http://www.hobbycity.com/hobbyking/s...y_Pack_Charger
mtbkym01 is offline
Old 09-20-2010 | 05:55 AM
  #17
And another...from US, with less shipping that Int'l S&H....
http://www.hobby-lobby.com/quattro_b...ers_in_one.htm
Duster_360 is offline
Old 10-01-2010 | 11:12 PM
  #18
tristyn's Avatar
Default x4
Has anyone actually used this charger. Looking to upgrade my Ice charger. Is this a quallity charger, durable?
tristyn is offline
Old 10-02-2010 | 04:29 AM
  #19
Briguy's Avatar
I ordered the Hobby King one and should have it any day now .
Briguy is offline
Old 10-02-2010 | 04:35 AM
  #20
pakk's Avatar
They only come with two balance leads?
pakk is offline
Old 10-02-2010 | 04:38 AM
  #21
its still a 50w charger.. making it no better than the ($50 less than the hobby king badged version) Accucel 6 with a few charging harnesses.. unless you want to do 5 or 6s packs in which case the accucel 8 is still cheaper and way more powerful
i use an ancient laptop psu (15v 4a) to power my 6, loves it
skree is offline
Old 10-02-2010 | 08:43 AM
  #22
Have you considered a balancing charger with enough power to charge the number of lipos you want to do in parallel? I've seen 6 lipos charged at once by a single charger. I've only done 2 at once in parallel, but that was at 2C charge rate (20amps).
Old 10-02-2010 | 09:16 AM
  #23
tristyn's Avatar
Default charger
Duster I run nitro 90% of the time so I am usually charging receiver bat. ,the occasional bump box bat. and transmitter bat. I run the ballistic 2700 nimh and 2000 lipo's for receiver, lipo and nimh for transmitter, 12v gell cell's for bump box. My son does run an electric slash so I do charge some stick packs. I would like to be-able to start buying the Life bat. for receiver and transmitter and the Ice says it will not charge Life. I have looked at a few chargers just not sure which to buy. Any advise would be great!
tristyn is offline
Old 10-02-2010 | 09:45 AM
  #24
the cheaper turnigy accucel 6 and 8 charge 12v lead-acids, lipo, li-ion, nimh, and LiFe.
skree is offline
Old 10-02-2010 | 09:48 AM
  #25
The Ice came out long before LiFes came out and which is the reason it (or its twin charger, Team Checkpoint 1030) doesn't charge LiFes.
You're charging a variety of batts and not demanding much in the way of charger output power, so a 50watt charger is fine. If you want to charge several diff batts of diff type at once, one of the Quad chargers might be suited to that purpose. Here's a review/discussion on the HC Quattro -
http://www.rcgroups.com/forums/showt...highlight=quad
If it doesn't matter having ability to charge diff type of batts at the same time, then just pick a replacement charger thats maybe a little better than the Ice. This would be a decent replacement -
http://epbuddy.com/index.php?main_pa...products_id=30
It does all chemistries, is a balancing type charger like you need for LiFes and has enough power to provide some flexibility if/when your needs change later. This is not the same charger HobbyCity cells for half price - I bought one from HC at this price, then a few months later, I noticed it was selling on HC for half as much. Thats also when I started seeing numerous complaints about it not working right being posted on RC Groups - HC must have asked for some at a diff price that were somehow cheaper (like no QC?). Mine has been fine in almost 2yrs useage, no probs. If interested in this one, you could discuss this with EP Buddy, I know they stand behind their chargers.
Another poss replacement would be the iCharger 106b -
http://epbuddy.com/index.php?main_pa...&products_id=1
Old 10-02-2010 | 12:28 PM
  #26
LunchboX3904's Avatar
it's 50w x 4. so it's more like 4 accucel 6's and much easier to carry around than 4 seperate chargers . so those of us that only use 2s or even 3s, it's great. i'll probably get one down the road
LunchboX3904 is offline
Old 10-06-2010 | 11:15 AM
  #27
Briguy's Avatar
My HobbyKing Quattro charger came today ! Came with a bunch of different charge leads and two ballancing leads and taps .
Operation is exactly like my Losi Intelligent charger and been charging batts to get ready for tonight . It will be much better only bringing one charger to the track . For size , it is a little bigger then the Ice but smaller then having two chargers on the pit table .
Another great inexpensive product from Hobby King !
Briguy is offline
