Dx3s Battery Voltage
Unless you are running an external bec or rx battery pack the voltage indicated on the screen will the the bec output voltage from your esc (it will not change regardless of battery pack voltage)
Spektrum sell a separate telemetry module setup that will monitor pack voltage, it requires additional sensors and wiring
Link below will run you through it
http://www.spektrumrc.com/Articles/A...ArticleID=1882
Cheers
Cheers
