Standard size servos splines guide >
Old 09-15-2010 | 10:58 AM
R/C Tech Elite Member
Default Standard size servos splines guide
When picking up a servo horn, it may be difficult to buy the right one for your servo because manufacturers don’t use the same number of splines for their servo output shafts. Here is a quick reference guide to help you to select the right horn for yours servos.
Pay close attention to your servo, some servos are rebadged servos from other brands. This is the case of the Hobbico CS-170 that uses 24 splines (Hitec) instead of 25 splines traditionally found on Hobbico servos.
* Ace/Thunder: 25T
* Airtronics: 23T
* Blue Bird: 25T
* Cirrus: 25T
* Duratrax: 25T
* Futaba: 25T
* Hitec: 24T
* Hobbico: 25T (Some servos like the CS-170 uses 24 splines)
* HPI: 25T
* Jr: 23T
* KO: 23T
* MRC: 23T
* Multiplex: 23T
* Sanwa: 23T
* Savox: 25T
* Tamiya: 25T
* Team Associated: 25T
* Tower: 25T
* Traxxas: 25T
http://www.myrcbox.com/?p=4396
Sylvain is offline
