question about a 3pk >
Old 08-29-2010 | 07:03 PM
Default question about a 3pk
just got a used radio. the trim adjustments by the wheel dont work. only one set of the four work. the throttle only.. is this normal? and is there n e where to get parts if its bad?
kwb0748 is offline
Old 08-29-2010 | 07:18 PM
rezenclowd3's Avatar
It may be that the switches or buttons have not been assigned to an adjustment. The manual which is downloadable on Futaba's site explains this process.
rezenclowd3 is offline
Old 08-29-2010 | 07:30 PM
Get the manual and make sure they have not been re-assigned or disabled. Manual is available here - you just about can't do without a manual with this radio -
http://www.futaba-rc.com/manuals/index.html
They must be doing maintenance cause I can't get their site to come up....
Duster_360 is offline
Old 08-30-2010 | 06:30 AM
They've probably been re-assigned, I would just perform model memory reset to return to factory defaults. Chances are that everything will be fine. I turn DT 3 off so I don't accidentally change my third channel trim for my killswitch, slave servo, etc.
Steve. is offline
Old 08-30-2010 | 01:39 PM
WELL THE ONE ON THE TOP DONT CLICK AT ALL WHEN YOU HIT THE BUTTONS
kwb0748 is offline
Old 08-30-2010 | 02:04 PM
It won't do anything unless it has something assigned to it.
VA_Racer is offline
Old 08-30-2010 | 02:10 PM
I DONT MEAN SOUND CLICKS.. I MEAN LIKE THE BUTTON MAKING CONTACT. THE OTHERS ATLEAST CLICK IF U PRESS IT. THE SOUND AS IF THE BUTTON WAS MAKING CONTACT..
kwb0748 is offline
Old 08-30-2010 | 02:58 PM
neobart's Avatar
OK we get you, now please stop yelling.
I hardly use the trim buttons, I always end up adjusting my trim accidentally in the heat of battle, so all my trim buttons are disabled.
neobart is offline
Old 08-30-2010 | 03:24 PM
SORRY I AM NOT A COMPUTER NERD.. I DO ALOT OF WORK ORDERS SO MY CAPS LOCK IS ALWAYS ON. I AM NOT YELLING.. BUT N E WAY. THE BUTTONS ARE STIFF. THEY WONT CLICK AT ALL. NOT BEEP ON THE REMOTE..BUT CLICK AS THEY WERE BEING PRESSED..
kwb0748 is offline
Old 08-30-2010 | 04:33 PM
Integra's Avatar
If there's 2 thing's i Highly suggest buying Brand new, Its Radio's and Motor's....You simply do not know how the previous owner has treated the unit and from what ive personally seen some guys are Super Rough with their TX's and wonder why everything is squeaky and falling apart.
Integra is offline
