An alternative receiver choice for the 3pks.
hi guys.i have a futaba 3pks at 40mhz.i want to buy a second receiver for my cars.
there are any different brand receiver that can work with this transmitter?
any help will be appreciated!
I've not been able to mix crystals like that, it seems to only work if you use a TX and RX crystal mde by same company.
I have a 3PK and run ppm and pcm setups. I also have a 2.4Ghz module and run a few like that as well, all ppm.
i learn the hard way that i shouldn't!
Yes, when I'm running in ppm mode, I don't have a failsafe. Thats the reason the only cars I use it in are 18th scales.
Are you running nitro or elec? Nitro its easier to deal with, can add a separate failsafe. Elec there's not really a good answer besides having the failsafe builtin to the rcvr.
What i meant was to have the same freq. The Tx should be on Futaba xtral always but if you're going to use a sanwa rx u'll need the rx xtral for sanwa.
yes i know that.i was searching an alternative receiver that can work in hras,because i want to have fail safe.i just don't want to add anything else in the car.
thank you for your help!
