RUNNING HOT!!
Old 08-13-2010 | 07:17 PM
MTclassPro's Avatar
Default RUNNING HOT!!
well i have an 18t with a 3s turnigy lipo (yes i know theyre cheap, dont need to hear it) and a mamba 25 esc... eveerytime i run it the esc runs pretty hot, havent taken any temp readings but its hot to the touch , and the motor, at times when its hot out gets VERY HOT, ill drop a tiny bit of water an it sizzles away, what is wrong with this, can i program on my castle link to make it not be so hot? and i do have a micro fan i can cool it down with but still need to know how to fix it....
MTclassPro is offline
Old 08-13-2010 | 07:33 PM
Sounds like you may need to charge gearing, tweaking the esc is prob not going to solve an undergeared prob. What motor kv?
Duster_360 is offline
Old 08-13-2010 | 07:36 PM
MTclassPro's Avatar
tekin mini rage 8000
Old 08-13-2010 | 10:52 PM
G33Kster's Avatar
Yup sounds like high gearing - if you're running stock gearing with that fast of a motor you should definitely be geared down if you want to run for more that a few minutes. Also, not sure about that particular motor, but most 8000Kv motors are only rated for 2S.
G33Kster is offline
Old 08-14-2010 | 06:47 AM
As long as you're using low stating power and no timing on the esc the temp probs will have to be addressed by gearing changes. Try smaller pinion and see how much that drops temps.
From what I've seen, this motor and kv have a rep for running hot and gearing doesn't help that much. If its runnning over 200F, it won't last long, you'll weaken/demag the magnets inside the motor.
Old 08-14-2010 | 12:01 PM
MTclassPro's Avatar
I've got a 60t spur on it now and I'm not sure about the pinion, but what kinda kv would I want for a 3s, 6800?
