-   -   li-po connection ? (https://www.rctech.net/forum/radio-electronics/423880-li-po-connection.html)
bigshow 08-08-2010 06:51 AM
li-po connection ?
if i wanted to run 2, 2s lipos on my losi 1/8 esc ,would i run them in series or the other way ? thanks
Duster_360 08-08-2010 08:52 AM
If you want to run them as a 4S pack for 14.8v nominal, you'd use a series connector - in series, voltage adds, but capacity (mah) stays the same.
If you want to run them as 2S at 7.4v nominal, you'd use a parallel connector since in parallel, voltage stays the same, but capacity (mah) adds. You'd typically do this to increase run time.
