3pk adjuster function >
Old 07-25-2010 | 07:50 AM
gfilos's Avatar
Default 3pk adjuster function
hey guys,
was playing around with the functions of my 3pk and i used the
adjuster to see my settings. Steering is perfect with 0% neutral
and same end points at 117. However throtle neutral is 34% but
both endpoints are same at 120. Is this a problem? After calibration
settings can be stored and says ok at both steering and throttle.
gfilos is offline
Old 07-25-2010 | 08:25 AM
Unless it doesn't work right when you run with it, there's no problem. 'Funny' looking numbers are not unsual. Mine are not centered either.
Duster_360 is offline
Old 07-26-2010 | 02:18 AM
gfilos's Avatar
thanks, in fact i think it works just fine. Guess i could fix it to center but i dont like messing with electronics.
gfilos is offline
Old 07-26-2010 | 07:44 AM
Yes, but there's really no point in it. Then if you ever change anything, that's just more work to do. I don't worry with it past getting it set up correctly.
