need input on charger. >
Old 07-21-2010 | 07:57 PM
  #16
how many watts is this quadra pro 2 charger have ive been searching high and low and come up with nothing also if charging 4cell can i charge a 5 amps or will it charge at 3?
toyota 2jz is offline
Old 07-21-2010 | 08:02 PM
  #17
Looks to me like its specs are 5 amps @ 5s which would make it a limited 100 watt charger
It would be capable of charging a 5000mah 4s pack at 5 amps
Much better options around for the money, including the Icharger 106b+ mentioned earlier in the thread
Cheers
crusey_aus is offline
Old 07-21-2010 | 08:13 PM
  #18
ok thanks for the input man
Old 07-22-2010 | 07:15 AM
  #19
Not sure its a 100watt charger based on the lipo specs - that's no diff than the Accucel-6 which is rated for 1 - 6S and is only 50watts.
The 1-14cell NiMh at 5a spec is what makes it look like its 100watts charger.
I don't understand why they don't simply say what the power output really is. Its like they're hiding something to try and justify the $170 price tag. LRP should know we need/want to know a charger's output power.
Duster_360 is offline
Old 07-22-2010 | 10:28 AM
  #20
just called ae and it is a 50 watt charger
Old 07-22-2010 | 11:37 AM
  #21
nickdawg18's Avatar
i guess thats not good for a $170 charger right?
nickdawg18 is offline
Old 07-22-2010 | 11:53 AM
  #22
Not for that kind of money when you can get a 50watt charger thats just as good for $55, or get a 350watt, 20amp max charge rate charger for the same money.
Old 07-22-2010 | 11:59 AM
  #23
yes most def
very true
