Mamba max pro problem
I recently bought and installed a mmp in my 2.0e with a tekin 1900kv motor. Everything worked great for a few practice laps but when I went home and tried to run it up the street it had a problem. The steering servo would only twitch and there was no power to the motor. I put on a CC BEC and pulled the center wire from the ESC. This took care of the steering servo but the motor still will not run. I re-calibrated the ESC and the lights show green under throttle and red under braking and yellow in neutral but the motor does not run. It also was having sporadic issue with not powering up so I hard wired the switch to eliminate that as a problem but it still seems to not come on sometimes when I plug the battery in. The steering servo still functions though because of the BEC. When I was trying to re calibrate the throttle end points it took several tries for it to enter the calibration mode but it finally took.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
