balancing thunder power?
have a few thunder power lipos, 2 cells. i have team checkpoint charger and balancer. is there some kind of an adaptor to balance these lipos?
thanks
thanks
any help?
hardcase
thanks
thanks
Yes check your LHS
So your pac has a balance connector like this -
http://www.rclipos.com/TP8000-3SSRT.htm
If thats correct, you'll need this to plug into the balancer - this adapts to a regular 2S JST-XH type balance connector (also called an Align type connector). Unfortunately, TP doesn't use this style so you'll need one more adapter -
http://www.rcaccessory.com/tptoalignjstxh2s2s4pin.aspx
This will plug into the balance connector on your TP lipo, then the other end will plug into the new adapter that plugs into the balancer. Team Checkpoint doesn't offer an adapter other than the XH (Align) type.
