Team Checkpoint Soldering Station problem >
Old 07-06-2010 | 12:29 AM
fievel's Avatar
Default Team Checkpoint Soldering Station problem
I have had the TC-950 for about three months now and it has been working great up until this past weekend. I am having trouble with the knob used to change temperatures. If I set it at 500 for example then turn it up to 600 it shuts off. I had the iron set to 650 and was having a really hard time getting my solder to flow, i used my temp gun to check the tips temp and it said it was only 256*. If i play around long enough with the knob I am able to solder with it but I really have no idea what the temp is. Is there anything i can do to fix this issue? Thanks
fievel is offline
Old 07-06-2010 | 04:37 AM
Seems you'e not the only one thats had probs with one. You might want to contact them -
http://www.bestrc.com/teamcheckpoint/contact.html
Duster_360 is offline
