-   -   setting steering endpoints???? (https://www.rctech.net/forum/radio-electronics/411606-setting-steering-endpoints.html)
nitro crazy 06-26-2010 08:34 PM
just wondering if you set steering endpoints with the car on the stand or setting on the ground, don't want to burn up my servo... thanks....
vti-chris 06-26-2010 09:37 PM
Both...and even pressed down!!:sweat:
NitroXray80809 06-26-2010 09:40 PM
i do mine on both both off the ground is my first setting with no pressure on servos o do it to hear for it making noises ive burt servos from not doing endpoints and the best way sinc is off ground listen for buzzing if ur car hit maximum steering wothout buzzing its still safe to put ur endpoints a lil less then full steering in case u hit somthin ur servo will be able to flex more without any binding up and possible breaking
Duster_360 06-27-2010 09:10 AM
I make an adj while off the ground to get them close and then sit it on the ground and let suspension come to its normal ride height. Then adjust to where its just barely touching and back off til I can just see clearance on both sides.
Dave H 06-27-2010 02:51 PM
Correct, check it though the full suspension travel, and after setting camber, toe in, and such. Leaving a little play.
Dave H 06-27-2010 04:19 PM
P.S. If you have sub trim on your radio, use it to center your steering before setting endpoints/travel/whatever your radio calls it. Then use regular trim for ongoing fine tuning after setting endpoints.
Reason is sub trim moves endpoints, regular trim does not. Same applies to other channels, throttle etc.
Never hurts to recheck endpoints occasionally either, in case anything wears/deflects/etc. Its easy enough to do.
Bonus points for driving slow circles each way, check for equal turning radius in each direction. :nod:
