Hi guy's.
Does the minimum drive setting once increased to say 5% for example, only work for the first pull of the trigger and then revert back to 1% or stay at the higher level permanently?
once you set the min drive value, it will be at value all the time at part throttle
it will never be lower than what you set it at. this setting is meant for responce and punch.
