Interferance between battery and receiver
I have a kyosho outrage that has an interferance problem at full throttle it wants to turn to the right but it wont to the left at any other throttle setting it will turn either way but not at full throttle. If I move the battery away from the reciever it seems to work fine but i dont want to relocate the reciever. About 4 months ago it worked fine so I just dont understand the problem. It runs at 75mhz and had previously upgraded to a esc about 6 months ago. Any help would be appretiated. Thanx
Here it was the motor causing the interference with a very worn com and no brush tension it was creating a lot of sparking which was the problem. I switched the motor with a known good one and shes ready to go again.
