-   -   Help with Hi Voltage Receivers (https://www.rctech.net/forum/radio-electronics/406932-help-hi-voltage-receivers.html)
moisesing 06-10-2010 07:17 AM
I need help, because I was told by a friend that all receivers can work with a LIPO Battery conected without a Voltage Regulator, what I have to ensure is that the servos I connect to the receiver are High Voltage servos.
If any one has a proper answer to this questions please your feedback will be much appreciated. At this moment I am running a Futaba 3PKs with a HRS 75Mhz receiver.
td-civ 06-10-2010 10:38 PM
your rx can take it and it will not burn it out as long as you are running hv servos your good
Z4Kevo 08-16-2011 08:41 PM
Bringing this thread back from the vault...
Just curious if anybody else has had success running a R603FS at 7.4v with multiple high voltage servos?
I have been running this basic setup (KO 30101 steering and Savox 1268TG mech brakes both at 7.4v) for over two months now without any issues. I do use a CC BEC to make sure the Lipo voltage is regulated to 7.4v, but thus far the receiver seems to be handling the increased voltage.
td-civ 08-16-2011 10:12 PM
all rx today can take up to 9 volts
