Deans connectors MELTED.
Hello,
I'm new I used the search button, and I couldn't find anyone experiencing the same problems. Currently I'm running a AE SC10 powered with intellect 3600mAh 7.2v NIMH batteries with a Castle sidewinder ESC and Axial transmitter. I took the truck out for a drive on a lightly damp baseball field, and when I went to change batteries they were stuck together. After I got home I ripped them apart, only to find the insides brown and bubbly. If anyone could please help, it would be awesome.
It takes a pretty serious current draw to melt a generic "T" plug, even more for an authentic Deans Ultra. I would suspect you have some major binding in your drivetrain, or maybe your pinion is way too tight. Whatever the problem, you will be lucky if it runs again. Electronics will not handle those kinds of draws very well. Motors will demagnetize and Nimh packs will cook from the inside out.
Look I was able to melt a tamiya and fuse it solid running a 18th scale with 3500kv brushless setup and Mamba 25, so I am not surprised at all.
Anything that comes with a Tamiya needs to be changed immed if you're goingto run brushless. You will melt it and if you're unlucky, when it fuses, it can short together and cost you your electronics.
Any other high current connector (XT60, EC5, Deans etc) is better than a tamiya.
