Opinions on this ESC? >
Old 05-05-2010 | 02:29 PM
Default Opinions on this ESC?
http://www.hobbypartz.com/vose6abresc.html
Was looking for cheap ESC's to replace the stock on my micro-dt. Found this one and if i did the math right, the cont. amps should only be 2.3-2.4 and this can handle 6. It has everything i need though i don't know about reversing.
What is everyone's opinions on this ESC inside a micro-dt? And i hope this is the right section. Was confused between this one or the micro though it's more related with the actual ESC.
EDIT: Was it bad i connected the stock 4.8 nimh battery to the motor without any ESC in between? The motor spun slower and slower though in the videos i saw a 9 volt battery connected right to the motor for 2+ minutes on how to break in your motor. Did i break the motor doing this?
krone6 is offline
Old 05-06-2010 | 09:16 AM
I have a question now. Will this ESC work with a brushed BB2 motor? I am so used to castle ESC's i forgot about that part. I hope i didin't waste 12 dollars.
krone6 is offline
Old 05-06-2010 | 11:33 AM
That ESC will work ok if it has brakes, but I didnt see anything listed. But it will not run brushed motors.
Your motor should have been fine, it was likely your battery dying that caused it to get slower and slower.
burnineyes is offline
Old 05-06-2010 | 11:39 AM
Does the losi brushless micro do brushed? If not i guess the castle is the only thing i would have left.
krone6 is offline
Old 05-06-2010 | 04:32 PM
not sure about the losi, I dont know many others besides popular 10th brushless ESCs that do brushed.
Old 05-06-2010 | 06:29 PM
simplechamp's Avatar
If you want a new ESC you will also need a new receiver and new servo. The stock Losi micro unit is an ESC and receiver in one, and the stock servo doesn't use the standard 3-wire setup.
simplechamp is offline
