FLYSKY GT3b Transmitter
#4816
quality control
pretty typical for me too... try rebinding the Rx... if that doesn't work, then try replacing the Rx, if that doesn't work then switch to a better quality brand.
I once owned 10 radios from Fly Sky... I'm currently down to 2 left working of the original 10 that I bought. Most started giving me problems as early as 6 months into using them... two of them have been going for nearly 5 years without a single glitch... kinda hit or miss on the quality overall.
#4817
#4818
Hey guys can you help me? Just got my GT3B today and I'm having some troubles. Of course the manual is no help. I can't figure out how to get the forward/reverse set up correctly.
With 1 & 2 both set to NOR, turning the radio wheel left turns the tires right, and pulling the trigger makes the car go in reverse.
Setting 1 to REV and 2 to NOR makes the wheels turn in the correct direction, and pulling the trigger makes the rear wheels turn as if to go forward, but the motor thinks it's going backwards. I know this because the motor only brakes when pushing the trigger then pulling it, not the other way around. Also, the motor only spins about 50% of max speed when pulling the trigger, vs 100% when pushing.
Setting 1 & 2 to REV makes the front wheels turn correctly, but now pulling the trigger makes the car go in reverse (albeit at 100% speed).
Setting 1 to NOR and 2 to REV makes the front wheels turn the wrong way, and pulling the trigger makes the car go in reverse at 100%.
Please help.
Please help.
#4819
This video shows how to set up the fail safe:
https://www.youtube.com/watch?v=BXKC5wffI44
Thanks for the link.
I've read that the expo didn't work on these radios a first. Has that been fixed on the newer ones?
#4820
I've got two radios, one is working fine, the other don't There is a guy selling upgraded software and upgraded radios
http://overkillrc.3dcartstores.com/G...g-Kit_p_9.html
#4821
Can anyone tell me the difference between the GR3C/E/F receivers? Will they all work with a GT3B Tx?
EDIT: Also, additional question: I hacked my GT3B with 0.6.1 firmware, but now I can only adjust the steering endpoints in one direction, to the right. When I turn the steering wheel, it doesn't change which way the arrow is pointing. Anybody else experience this?
#4822
I have the FLY SKY FS-GT3B, and recently I was able to truely play with my RC at a large parking lot (very large). So, my problem is, at about 200-250 feet my connection to the Tx and Rx are lost. I walk closer to the car and it's back. Range issues.....
Has anyone else experienced this with their FLY SKY FS-GT3B? I am using the receiver that came with the control. And I am controlling a Revo 3.3.
I have done nothing with the firmware or SW on the control.....everything is stock.
#4823
These FlySky radios (Tx) are very very good and I like them, but the Rx are a bit circumspect. I think early ones (Rx) were hit n miss.
#4824
It looks like I have some trouble with the potentiometer from the throttle trigger from my GT3B . Does somebody knows where I can buy a replacement potentiometer ?
#4825
Flysky gt3b issue.
My son has a Flysky GT3B radio, he purchased it 3 months ago. Just recently I bought him rechargeable AA batteries (duracel). AA batts were fully charged before using them. After 2 bash sessions with that Tx and rechargeable batts, the low battery alarm started going off. Voltage showed below 8.4v......remind you, only two bashing sessions around 30 min. each. I swapped the rechargables to regular duracel batts while the others recharged. With a fresh pack of AA, the alarm is still going off and it shows the voltage at around 8v, remind you again, it's a fresh pack of AA. I'm not sure if its the Tx tripping out, or if I did purchase some bad batts. Im going to get another pack to try it again.
Has anyone else experienced this type of issue with this radio?
Folks, I know this is a cheap radio, please be cool....i'm trying to troubleshoot this issue for my son. He has 4 other cars linked to this control, so i do want to try to resolve it without having to go out and purchasing a tx and a few rx's.
Any help would be greatly appreciated!
**no upgrades have been done to the tx....firmware, mods, etc.....it's bone stock.
#4826
What are the mah on the rechargeable batteries.
#4827
Can you check the voltage with a multimeter?
#4829
#4830
It takes a few time for rechargeable take their max amperage, I use 2700mah AA on M11, last at 1hr and a half. 8.5 voltage it starts to giving low batt, it should. I starts at 12 volt, 8.5v they loose efficient volts for TX to operate.
Give a few charge times for rechargeable to be more amperage efficincey. What do you use to charge the batteries. Hopefully you use a charger the go 500ma only. Anything higher will overheat the batteries, heat kills the batteries.
Rechareables low voltage will stop immediately, not like alkaline.Maybe the TX went bonkers of alkaline were bad already Try another set a batteries!! Got me stumped!!!
