FLYSKY GT3b Transmitter
#3916
ok. do you know where the dsc port is connected to? Is it just the ppm signal? I looked briefly but couldn't figure it out without pulling the board out which I didn't really want to do. It would be nice if you could use that it input a signal.
#3917
DSC port is PPM signal out and it is directly connected with HF module "PPM signal IN".
#3918
that is what I would have expected. I must have looked at the wrong pin on that connector with the scope.
#3919
Where do you guys actually buy the programmer and the recom voltage regulator?
Ive been looking all over and it seems to be hard to get where I live (30 dollar shippingcosts on a regulator? B**ch please..)
I need a place that sells to Europeans without ripping you a new one on shipping.
#3920
#3921
new firmware 0.6.0
Hi,
I did some more changes and new firmware is out. This one will delete all configs (global, models). But there is some extra space in global/model config now, so it is possible to add extra functionality in the future without deleting all configs.
So main changes:
There were big changes from version 0.4 in the last time, so it will need some testing to check if all is working. If there are mistakes/non-functionality, report it to get it repaired.
So main changes:
- Use FLASH memory to store model configs also. But look at MANUAL, how to program it with STVP and not delete model configs stored at FLASH.
- There are 67 model memories now (QuangVuong, is it enought ). But if firmware grow in the future, model memories with highest numbers will be lost.
- There is only one 8-channel firmware now as there is enought memory models. Global config "default channels" contains number of channels, which will be set to model config by default.
- There are 4 multi-positions now, with 8/6/4/4 positions.
#3922
The voltage regulator: XP POWER - SR05S05 - SWITCHING REGULATOR, 5V, 0.5A O/P
#3923
-Goat-
#3925
Plug in your STM8 Programmer and clear the Data Memory field on your radio. Full reset.
#3926
Its asking me for a VAT number, so I guess not?
#3929
Hi,
So main changes:
So main changes:
I have not looked over the manual, but I assume within the firmware options menu, you will find a setting to specify how many channels? You combined all separate channel firmwares, correct?
#3930
yeah. you can specify the number of channels for each model.
