HPI Flux Blur Brushless Esc Question?
Easiest way is thru the Castle Link where you can access it directly. If you don't have one, you should. I think you can also use the Field Link. The reverse type can also be changed manually using the controller - see pg20 (manual prog sequence starts here) -
http://www.castlecreations.com/suppo...s_ed_guide.pdf
