OK WHAT THE HELL IS WRONG??? 4PK PROBLEM??? >
Old 03-29-2010 | 12:33 PM
forty6and2's Avatar
Default OK WHAT THE HELL IS WRONG??? 4PK PROBLEM???
ok im stressed out?!!!!!
quick break down
1.own a 4pk radio and numerous 603fs rxs
2.bought NEW sc10 stock electrix(esc,motor).
3.determined i had no output on the stock esc steering worked no throttle, light working)......
4.bought an lrp 80100 esc to replace stock esc NO PROGRAMMING NEEDED!!!!
5. got it today ,hooked it up, turned it on, SAME MUTHERF*&CKIN THING!!!! no throttle.
is there something in this friggin radio that i need to change switch,.....SMAAASH
this is friggin retarded.
i am new to electric stuff, but not an idiot,
my tc5 with a novak esc works perfect! not sure why i can get this other ear working!!!
i keep having to dissapoint my daughter cuz she cant drive her truck!!
PLEASE HELP MEEEEEE!!!!
forty6and2 is offline
Old 03-29-2010 | 01:22 PM
forty6and2's Avatar
just bound my daughters 3PM to the unit.. still nothing
not sure why but i also tried a lipo in the system.. just plain and simple for the life of me i cannot get this to go !!!! ive read the 4pk manual 3 times today!! been googling for hours now
grrr
Old 03-29-2010 | 01:29 PM
oeoeo327's Avatar
Some ESCs require the throttle channel being set in the reverse position to work properly. I'm not sure if that's the case for all ESCs (I don't own a 4PK), but it'll cost you nothing more than a few minutes to give this solution a try. Don't forget to recalibrate the controller to the ESC once you've reversed the throttle.
oeoeo327 is offline
Old 03-29-2010 | 01:35 PM
forty6and2's Avatar
thanks man, tried it still nothing.
i did notice a bit of a high pitch wine when i squeeze the throttle, but no movement
Old 03-29-2010 | 01:36 PM
i would 2nd that. try reversing the throttle channel. for some reason this is still an issue even on the most expensive ESCs. i have no idea why, but thats what the reverse channel function is for.
edit-damn nvm then.
try changing the epa's to higher or lower settings.
benben10 is offline
Old 03-29-2010 | 01:48 PM
Kent Beal's Avatar
Is the battery charged?? some lrp esc's come with them in lipo mode and if the batt is low it will whine but their isn't enough amps to make the motor go.
hook that lipo in your tc5 and see it works since you know that rx,esc,motor, system works.
you can also reset the model memory on your 4pk so it will at factory default settings. Also make sure that the sub-trim is at zero and the epa is at 100 high and low. Some esc's don't like the epa to be 120 high/low.
Kent Beal is offline
Old 03-29-2010 | 01:53 PM
forty6and2's Avatar
just took a new batt off the charger
sub trims are at 0
epas are at 100
i can hook the batt direct to the motor and it goes full bore!
ok on the lrp esc i have an orange, yellow and a blue wire, what goes to what?
the stock brushed motor has a blue and yellow, i didnt get a manual with the esc and ae site is doing some maintenance so i can get it to get one.
Old 03-29-2010 | 01:57 PM
forty6and2's Avatar
did a model reset as well.. still nothing
going for a nap.. thanks for all the help and suggestions,
if anyone else has any,, fire away!
Old 03-29-2010 | 01:59 PM
wikedgmc's Avatar
sounds like your esc is wired incorrectly, I know 2 wires go to one terminal but I have not done it in a year and do not remember. Someone here will be able to help or the site will come back up.
Sounds like your radio is good
wikedgmc is offline
Old 03-29-2010 | 02:09 PM
Hi,
on lrp speedos for brushed motors
orange wire to "+"
and blue and yellow together to "-"
then it should work ;-)
Blade7 is offline
Old 03-29-2010 | 02:12 PM
Are you sure you have the wire from the esc plugged into the rcvr with correct polarity??
Duster_360 is offline
Old 03-29-2010 | 07:24 PM
forty6and2's Avatar
Originally Posted by Blade7
Hi,
orange wire to "+"
thats got it !! works like a charm, i guess if i had gotten the manual or ae site was up i would not have posted this at all.. feel kinda stupid now, figured i didnt need the orange
thanks guys!!
Old 03-29-2010 | 07:25 PM
forty6and2's Avatar
if there is one thing i know, its that
