-   -   Tamiya TEU-101BK (https://www.rctech.net/forum/radio-electronics/381588-tamiya-teu-101bk.html)
f1larry 03-19-2010 08:05 PM
Tamiya TEU-101BK
Is the TEU-101BK not able to be used with a 7.4v lipo battery? I have been trying to get one of these ESC's to work in my Rally Car but it doesn't seem to want to work with a 7.4v lipo battery. It works perfectly with a 6 cell nimh battery.
when I connect thel lipo the steering works but the ESC just flases red and beeps. Is there anything that can be done or are these ESC just designed for the 7.2v nimh batteries.
Thanks,
Larry
holeinone 03-21-2010 07:53 AM
I use 7.4v lipo on the same ESC. No issues.
gapjr 03-21-2010 08:56 AM
Hmmmmm....I have one of these esc's that does the exact same thing. I just thought it was dead but I was using lipos to try it out so today I'll try a standard 6 cell nimh on it and see what happens. I'll let you know ;).
94eg! 03-22-2010 01:31 PM
I installed deans on two of these this weekend to run lipo and everything worked perfect. Didn't have to recalibrate or anything.
Did you try doing a recalibration?
What motor are you using?
Does your receiver have built-in BEC?
f1larry 03-22-2010 03:46 PM
I got one to work the other just may be bad. Do you have to have the motor attached to get it to work?
NTLDR 06-13-2010 04:19 AM
Have you changed the connector to gold plated standard Tamiya plugs wont power liop's.
VooDooPH 06-14-2010 05:12 AM
my esc still has the standard tamiya plug... works fine with my lipo (although i had to make an adapter for a Deans type plug) and nicd packs
Xmod_Racer 06-14-2010 09:29 AM
my TEU-101BK doesnt even work with any battery. Says its not getting signal from my spektrum receiver. DX3S radio.
