-   -   Team associated XP Digital Ds1313 servo help (https://www.rctech.net/forum/radio-electronics/378670-team-associated-xp-digital-ds1313-servo-help.html)
guss2009 03-10-2010 01:37 PM
I bought this Team associated xp digital Ds1313 servo for my Losi 8ight 1.0 buggy. I have the Losi 2000 lipo battery on my buggy and would like to know if the lipo battery will or wont burn the servo? I have the servo brand new never mounted in the box. I would like to no more about it before i do anything with it. Thanks
geejay 03-10-2010 01:45 PM
that lipo will send that in to flames... you need to get a regulator
Team Losi High Output 5A Lipo Regulator w/Switch
[LOSB9608]
guss2009 03-10-2010 01:49 PM
[LOSB9608]
Yea i forgot to say i have the Regulator w/switch
geejay 03-10-2010 02:02 PM
you should be good then.......... the reg WILL reduce the volts to 6 or so..
you will be good.
guss2009 03-10-2010 02:07 PM
Where should i use it... On the throttle or the steering? I also have a brand new hitec 7955tg servo. Im going to be using those 2 servo on my losi 1.0 buggy. I also have 2 hitec 7955tg servo on my losi 2.0 buggy which i havent had problem with.
the_winner 03-10-2010 03:19 PM
I use the DS1313 in throttle with good results...
Landscaper 03-10-2010 03:35 PM
[LOSB9608]
Not true it will work without a regulator not recommended but will work, 3 months and no issues with mine
might not work well on your reciever though
dunnyrc51 03-10-2010 05:45 PM
I would use the regulator since the servo itself is only rated for 6v. DO NOT run it without the regulator it will burn up and then they will not warranty it because of that. Regulator's are cheaper than new servos.
guss2009 03-10-2010 06:07 PM
Im going to use it with the regulator since i have it. Im using the receiver that the Spektrum Dx3s come with in the package.
guss2009 03-12-2010 07:24 AM
So should I use the hitec 7955tg for steering And the DS1313 on the throttle?
I'm asking because I don't want the ds1313 to die out on my throttle and have my buggy run away from me.
