airtronics problem
hey all i have a airtronics mx-3 fhss 2.4ghz radio and im running it in my cyclone and im having a issue with the steering servo.
i have a hitec 645mg servo and a hitec 635hb servo and i have tryed both and when i turn the steering everyonce in awhile they "hang up". they hang up and start making noise like they are trying to move or some force are on them. i put my basic perfex ks-1401 servo on and it works fine and that servo if from my truggy's throttle. do you think my hitecs are giving up or is it a issue with the radio working with a hitec? im going to try with my slash servo to see what it does also |
Originally Posted by carcrazy699
(Post 7071978)
i have a hitec 645mg servo and a hitec 635hb servo and i have tryed both and when i turn the steering everyonce in awhile they "hang up". they hang up and start making noise like they are trying to move or some force are on them. i put my basic perfex ks-1401 servo on and it works fine and that servo if from my truggy's throttle. do you think my hitecs are giving up or is it a issue with the radio working with a hitec? im going to try with my slash servo to see what it does also Hard to say. But I have been running an Airtronics radio with my hitec servos and have not had any issue at all. If you suspect your servos might be on the way out, then try a new servo. If it does the same thing, then I would suspect a bad receiver. Shawn. |
thats what i was thinking. i put my throttle servo in it from my truggy its a perfex one and it work faster and quicker so im thinking the hitecs are just starting to give up
what speed controller / BEC are you using...?
Have you tried a capacitor on the receiver? High draw servos & low output from the ESC to the receiver will cause studdering much as you described... Unhook the ESC & throw a receiver pack on & see if the problem goes away. |
i will try that when i get home.
i have a speed passions gt2.0 carbon edition with the latest software. |
| All times are GMT -7. It is currently 02:57 PM. |
