Power supply Q
Old 02-22-2010 | 05:51 PM
hardhead's Avatar
Default Power supply Q
Will a 15amp PS run two lipo chargers @ the same time? like a TP 610 and ice charger??
Its a radio shack 13.8 15amp
hardhead is offline
Old 02-22-2010 | 06:07 PM
It will run them both as long as they are not using more that the ~200watts the power supply is generating. If the chargers are about 90% efficient, you'd have about 180watts to run both chargers. If you're charging 2S lipos, you shouldn't have any probs. If you're charging bigger cell counts, you will need to be careful you don't try to ask for more power than the supply can generate.
Duster_360 is offline
Old 02-22-2010 | 06:16 PM
hardhead's Avatar
Thats cool info thanks
hardhead is offline
