LIFE BATTERY
so i was looking at getting one of those protek life rx batteries for my 8th scale buggy. just wondering if i need a life charger? i have a trinity i-balancer charger, i wonder if it can do life batteries? i hope so! thx guys for the help.
ProTek R/C LiFe Flat Receiver Battery Pack (6.6V/1450mAh...so if these life batteries have a faster charge time whats the highest amp charge i can use? |
Your charger handles LiFe batts. As far as what charge rate, LiFe can be charged at 10-15C. 1C for this LiFe is 1.45amp. I think your charger is limited to 5amps so thats what to charge at - that would be about 3.5C.
If you had a more powerful charger, you could charge at higher rates, but charging at 5amps isn't going to be a prob either. |
Originally Posted by Duster_360
(Post 7033537)
If you had a more powerful charger, you could charge at higher rates, but charging at 5amps isn't going to be a prob either. thx for your help! |
If it doesn't have a LiFe mode, it should let you set the cell voltage under a general lithium batt type setup. You'd use 3.7v for lipo and prob 3.3v for LiFe - these may be set as options rather than variable. The programming inside the charger then knows to max the cell voltage at the correct amount.
Some chargers do it this way rather than have a separate LiFe mode like my Hyperion soes. Check the manual and make sure you use the correct voltage to trigger the LiFe mode. Yiour charger is advertised as doing LiFe, so this should be covered in the manual. |
thx Duster, after digging more into my manual it seems like your spot on! i understand now. thx for the help. listen to this guy,he knows his stuff!:nod:
| All times are GMT -7. It is currently 11:17 AM. |
