LRP sxx mode change
Old 02-20-2010 | 12:04 PM
kjdad's Avatar
Default LRP sxx mode change
Not getting something. How do I change the modes on the sxx TC esc? I know how to cycle thru them and see or change them, but how do I select the one I want to use? I am running lipo and want mode one. According to the instructions there are two settings under mode 1 but when I check what it is on it blinks the blue lite once, then 4-5 blinks on the yellow??
What am I missing?
kjdad is offline
Old 02-20-2010 | 10:08 PM
Default HERE IT IS
Hold the the MODE BUTTON untell it starts flashing... the first set of flashing is NICd or LIPP, if the right light is blinking 1 is on lipo, 2 is on NICd. you push the set button to change. The second one is POWER PROFILE. there are levels 1-10. average timing is 4. you just push the set button how ever many times you wanna step it up, after you get to 10 it goes back to 0. the 3rd is initial brake. follow the same steps, and the 4th is Drag brake. follow same steps. dont forget once you are finished with one of the steps you just puch the mode button to move through to the next one. there are 4 different set up after the 4th it will go back to normal. turn off your car then back on and your ready to go.
What am I missing?
rtlawlor is offline
