Mamba Max Pro 1 cell
On this new Mamba Max pro 1 cell, since there is no BEC, do you really need a BEC to use this ESC?
It also rated to run 1-6s, if you run 4s, do you need BEC>?
What is the effect of not having the BEC>?
You will need to use a BEC with 4S or a separate receiver pack. There are no receivers or servos that can run on that high of voltage. If you were only running 2S you could get away with running it directly to the receiver and using an HV-capable servo (that's what I do) but anything higher will require a BEC to regulate the voltage.
