rs 431
hi every1,
i just bought a rs 431 reciever but instead of writing ch1 ch2 ch3 slot,
the reciever got 5 slots, indicating ST, TH, AUX, BRK, B/D slot.
may i know which slot to put in for esc, servo and batt?
cos i kinda confuss by the wordings. thks.
ST = steering, #1, steering servo
TH = throttle, #2, esc
AUX = auxiliary, #3
Not familiar with BRK & B/D, but I’d guess possibly for a separate brake and then battery/something. Battery is usually last. Be surprised if they weren’t all in numerical order.
If you have an electric car with an esc, generally you wouldn’t need a separate receiver battery plugged into the receiver. If you do use a receiver battery for some reason typically you would need to pull and insulate the red esc wire, you don’t want 2 power sources battling each other, at least one will lose and possibly burn up.
AUX = auxiliary, #3
