Cant get my GTB to work???
Alright I just got this used GTB and used motor off a racer on here and want to test it so I can leave feedback but I cant get the throttle to work? I did the one touch setup and the steering works but no throttle.... so I looked up the manual and the ESC is showing me a solid red LED and a blinking green LED which the manual says:
check input and motor sensor harness - Did that and they are both nice and snug Then it says test the receiver by swapping out the thottle/steer wires and test - Did this and steering still works but no throttle.... so the channels are both good I dont know what else to try? Any one had this happen before? Please help me! :confused: |
I have re-done this process 6 times now all come out the same way?
Make sure you have the following settings on your radio.
Throttle trim 0 Throttle sub trim 0 Throttle epa hi and lo MAXED OUT may be more than 100% also try normal and reverse throttle setting. hope this helps |
I dont have those features on the currant radio it is a basic AM would this cause it not to work at all? I am ordering a spektrum soon but want to test this to make sure it works first.......
IS it not working due to the crappy radio? Does the GTP need a FM or Spektrum to work (for test purposes)? I just want to make sure the ESC/motor work before I spend more money.....
anyone have any ideas??????? I am stuck on this?
Originally Posted by 440swinger-kid
(Post 6914098)
Yeah I have a fully charged venom 3600 ni-mh battery and it has a Orion vortex motor with the sensor wire. I could not figure out how to mess with the lipo on/off and brushed/brushless setup?
Try a different motor. sounds like the motor or sensor wire could be damaged. And all plugs are facing the right way too.
Yeah when I received it the wire were in the wrong spots so I moved them to the correct spots and everything is nice and snug..... the only thing I see wrong with the sensor wire is two of the wires are missing a little coating from when they may have rubbed against something. Yeah I will try a different motor later tonight.
This may be a totally dumb no-duh thought on my part but what version of the GTB is it? If it is the Spread Spektrum version it won't matter what you do because it will not work with radios that still use crystals.
I think it is a original version but still waiting for the guy that sold it to me reply. The only sticker on it was the GTB and the other one with the wiring was gone. Could I find out with the sticker on the bottom? It is the barcode. I am thinking it is the radio though.
yea look at the code on bottom and go to novaks web site and see they got 3differnt gtb esc the site my have the info you need
Originally Posted by vintage10
(Post 6916364)
yeah the barcode dont tell me what it is..... but i am guessing it is a 1710 since the guy said it a couple years old..... I still dont know what else to do.
| All times are GMT -7. It is currently 01:24 AM. |
