airtronics m11 throttle calibrating?
Is there a way to calibrate an m11 airtonics radio?
i can't get the throtle to the center, it's always on the brake side. I tried trim and sub trim but it's not working. i actualy tried everything. Do i have to change the pot on the throttle or can it be fixed
Thanks for your help!
No not the actual position of the triger itself, the triger is fine but it reads on the radio that it's on the brake side a bit.
On my dx3r and nomadio sensor i can recalibrate the pot. I just can't find a way to do it. Or do i have to change the pot
I don't mind buying a new pot as long as i don't have to send it to airtonics, i'm in canada and it will take a while to send it and receive it back.
Really disapointed by this radio
I'd like to know that info also! I don't see it!! If its internal, on the board its not to be touched, but manufacture.
Dean If you are using MMPro. Your TX & RX is set. Its mostly the calibration of ESC. Calibrate it correctly it should be fine. Check TX on Start position & Throttle Hold (pages 31 & 32 in manual) It must be turned off, The two is used with nitro Engines only. Make sure your Trims for throttle at 12o'clock, EPA at 100% before you calibrate you ESC. Make sure you get tone(beeping) sound before to the next. Calibration sets your Neutral, full Throttle, and Braking on ESC.
I posted it earlier on the thread. See what happens!!
