RX question
Old 01-17-2010 | 11:01 PM
rpm1968's Avatar
Default RX question
Anyone have any input on running the Futaba R6004FF in an indoor offroad car?
thanks, Rev
rpm1968 is offline
Old 01-19-2010 | 08:44 AM
rpm1968's Avatar
any ideas? thoughts?
rpm1968 is offline
Old 01-19-2010 | 10:19 AM
I haven't ever heard of it but just from looking at the site it seams to be a Proprietary rx only compatible with certain tx's.
bob3104558 is offline
Old 01-19-2010 | 06:16 PM
rpm1968's Avatar
thanks for the reply "bob".
"The R6004FF receiver will not work with that transmitter as it is ground transmitter."
this was what I got from Futaba. I didn't know there was a difference in the surface & air 2.4ghz systems.
doesn't make sense, but I guess that's why I had to ask.
Rev
rpm1968 is offline
Old 01-19-2010 | 08:21 PM
PaPeRo's Avatar
I think Futaba keeps their surface/air systems separate because they require different design features. Air systems require more range than surface systems and normally have two antennas on the RX because aircraft can do 3D acrobatics. For surface systems you only really need one Rx antenna because cars/boats are 2D only vehicles.
PaPeRo is offline
Old 01-20-2010 | 09:00 AM
Same thing pre 2.4 - air used a separate frequency, 72 vs ground 27 or 75Mhz.
They have to be diff so there's no possibility of interference.
Duster_360 is offline
Old 01-29-2010 | 09:37 AM
rpm1968's Avatar
Thanks for the responses. Futaba said it is designed in to their "firmware" and the two are not compatible.
Rev
rpm1968 is offline
