M11 Radio Help
Old 01-16-2010 | 12:31 AM
Suspended
Default M11 Radio Help
Hey guys I have a Issue with My Radio. My Steering wheels position is not in the Neutral Position or Centered I guess. When I let the radio sit. You can see the bar a little more to the Right. I have to turn the Wheel left slighty to make it Centered. Does anyone know how do I center this Radio?? Thank you
PsycoB4 is offline
Old 01-16-2010 | 10:32 PM
Suspended
Anyone?
PsycoB4 is offline
Old 01-16-2010 | 10:43 PM
chunk62's Avatar
I had the same problem. This might sound stupid and redneck but take a rubber mallet and tap the center of the wheel a few times. They seem to get a little bound up. I found this out of dumb luck. I had this happen to mine and I was so pissed that I couldnt get it to work that I hit it with the palm of my hand out of frustration and it worked! My friends had the same problem and I fixed it with a rubber mallet! Hope that helps!
chunk62 is offline
Old 01-16-2010 | 10:53 PM
make a trim adjustment or recenter servo
bowl806 is offline
Old 01-17-2010 | 01:19 AM
Check your steering subtrim. If it's at 0 and the servo monitor says it's not centered, then you should calibrate the wheel, if your radio has that function.
breyton is offline
Old 01-17-2010 | 06:30 AM
Suspended
You are the Man!!!!
Worked Like wonders, Just yanked on the wheel a little and straighted right out.
but now the steering wheel goes to the right about 95% and I hve to push it harder to the right inoder to get that extra 5% any Idea why?
PsycoB4 is offline
Old 01-17-2010 | 07:25 PM
chunk62's Avatar
Im not sure on that one. Im glad that you gixed part of it anyways!
chunk62 is offline
Old 01-19-2010 | 11:48 AM
jnslprd's Avatar
send it back to airtronics for warrenty repair
jnslprd is offline
Old 01-19-2010 | 04:40 PM
WHEN YOUR WHEEL DOES NOT CENTER U NEED TO REPLACE THE SPRING,
IN THE STEERING WHEEL
TELL BETTS TO SEND IT IN TO AIRTRONICS
icemandolmite is offline
