spektrum 5.5ms
will the Futaba S9650 work with the spektrum 5.5ms setting?
I dont understand how it tells if its fast enough?
Servo specs
Speed: .14 sec/60 degrees @ 4.8V - .11 Sec/60 Degrees @ 6.0V
Thanks!
Servo specs
Thanks!
If it’s a digital servo it should work, which I believe the 9650 is. It’s not really about the servo specs, but rather how the electronics process the signal if I understand correctly.
It will be fairly obvious if not, at least it was when I tried it on an analog servo, the servo will probably buzz/be jittery/won’t respond correctly. I think there is chance of damage if you try it for too long.
