SLPB Lipo Balancing
Old 01-02-2010 | 09:38 PM
Questions?? SLPB Lipo Balancing
I need some help.
I have a GP4300 lipo. It doesn't have the ususal harness like my other lipo, just a single 2mm bullet terminal.
My Orion Charger has a harness output, and also two SLPB terminals labelled "A" and "B".
So, how do I wire up this Lipo for balancing? Is it as easy as connecting the battery 2mm terminal to "A" on the charger, and then using normalbattery charging leads?
JR007 is offline
Old 01-03-2010 | 10:24 AM
This is made for a Hyperion charger, but if you look at the diagram and picture, I believe you'll see what you need to do. The harness is also connected to the chargers balance port in some way.
http://www.allerc.com/product_info.p...oducts_id=3702
Duster_360 is offline
Old 01-03-2010 | 11:49 PM
That may work, but then I wouldn't be using the SLPB port which was what I was trying to do....
JR007 is offline
Old 01-04-2010 | 03:59 AM
Originally Posted by JR007
I need some help.
Exactly. 3 direct wires, the 2 main and a small "A".
The "B" on the charger is used for the 3 cell version with 2 small terminals. You can either use the A and B terminals, or the typical white plug multi pin thingy, but not both.
Dave H is offline
Old 01-04-2010 | 07:35 AM
nc-hopsing's Avatar
+ and - like normal and I use the blue balancing port lead on the charger....i think you can use either the blue or the green and it wont make any difference though.
nc-hopsing is offline
Old 01-04-2010 | 11:04 AM
Fantastic! I was hoping it would be that easy. Thanks guys
JR007 is offline
