-   -   Venom LiPo questions (https://www.rctech.net/forum/radio-electronics/356159-venom-lipo-questions.html)
Buddie 12-30-2009 08:56 PM
i am new to the LiPo thing. I just bought a slash 4x4 it will be here next week and was wondering if this would be a good battery? The
Venom LiPo 3S 2P 11.1V 6400mAh 20C
I know that they say not to but the nimh 6 cells under 3600 because of the quality but the higher ones are ok.
if not any good recommendations?
thanks for any info
JFuel11 12-30-2009 09:09 PM
You didn't say if the Slash 4x4 was the brushed or brushless version. If it is the brushed system then that would be a very good battery. However if the slash is the brushless version, I would suggest you look at a battery that has a C rating of 30C+ due to the amp draw of a brushless system.
You most likely will end up stressing a 20C Lipo with a brushless system and it may not deliver the punch you would expect.
Anything 11.1 Volt, 5000mAh or more and 30C or more would be a great battery for the slash 4x4 brushless.
Just my -98cents worth, Hope it helps.
Buddie 12-30-2009 09:25 PM
It is the brushless.
thanks for the input
Duster_360 12-30-2009 09:27 PM
Think this would be a good lipo considering its capacity and the C rating. This lipo will deliver 6400/1000 X 20 = 128amps continuous. Its the current which is a function of both C rating and capacity, not just the C rating by itself that determines what a lipo can produce for current. The high capacity makes up for a lower C rating in this case.
As long as it fits, think this would be a good lipo.
