-   -   xp 1015 servo problem (https://www.rctech.net/forum/radio-electronics/354280-xp-1015-servo-problem.html)
nitrobhoy 12-23-2009 03:20 PM
Hey guys my xp 1015 servo is playing up a bit, when moving it shudders a bit as if it is jitering, it is only slightly, any ideas...
captaindemo17 12-23-2009 03:24 PM
Check for play in the gears. Mine did this as well untill i replaced the gears.
nitrobhoy 12-23-2009 03:30 PM
thanks m8 will do
JodyJ 12-23-2009 04:25 PM
That's funny my JR 9100S that I put into the buggy did the same thing on steering LOL
smokinu 12-23-2009 04:37 PM
they tend to do that right before they blow up...
the servo is shaking because its trying to find center.
scoobie1 12-23-2009 04:49 PM
There are two things that will cause that, either the upper case, or the gears. If yours is one of the newer models, its most likely the gears, cause the case has been updated.
I had one with the shakes, and it worked fine as long as there was a load on the servo, it only had the shakes when it was off the ground. I ran it for a whole season like that!
I ended up buying the replacement parts and selling it to a guy with full disclosure that it had 'the shakes'. He replaced the parts, it fixed the problem, and still works to this day.
flame56mx 12-23-2009 04:52 PM
And that is "NOT FUNNY", but unfortunately, it is more than likely true, The end is Near..:cry:
smokinu 12-23-2009 04:56 PM
i had a 9000t that did it as well as taking the cs170 throttle servo and my lipo pack as well as my sr3001 rx that was an expensive day.
nitrobhoy 12-23-2009 05:17 PM
yep your bang on right there scoobie1, it only seems to be when no pressure is there, and it isnt trying to find centre but just like shudders very small shudders but it still works and has plenty of power in it, think i will have to open it up and have a look, anyboby know what am looking for there???:confused:
smokinu 12-23-2009 08:07 PM
when the front wheels are off the ground the wheels will "tick" back and forth correct?
that means the servo cant find its center point and steady itself. :lol:
Integra 12-23-2009 08:53 PM
Lol gotta love Ace.
NOT.
Bren Ralls 12-23-2009 10:27 PM
THis is a normal trate of the ace when the gears wear. A simple & non costly trick is to remove the top cover, the top gear is brass & its here where it wears in the centred point. Simply lift & turn it through 180 deg & you have a new set of teeth to wear to your hearts content..
joeling 12-23-2009 11:32 PM
Why Not ?
Originally Posted by Integra (Post 6758806)
Lol gotta love Ace.
NOT.
The Working Man 12-24-2009 02:27 AM
Originally Posted by joeling (Post 6759244)
Why Not ?
Careful. That man will Hi-tec you untill submit.:sneaky:
Bren Ralls 12-24-2009 03:15 AM
:ha: was waiting for them to wake up you know it will come.
